40mm waste flexible bends
24 Nov 2008
Has anyone an opinion of solvent weld flexible bends for 40mm wastes?
I can't seem to find much mention of them.
Have been looking at Magicflex Solvent Weld Elbow 1 1/2" from by Wirquinn from Toolstation.
I'm probably talking my usual rubbish here, but I would have thought that the traditional rigid solvent weld stuff (acrylic with filler based) would not have the flexibility that PVC products would have....therefore it would be important to use a proprietary PVC adhesive when using these?
John :)
The words "flexible waste pipe" will make any decent pro shudder, those ribs will trap dirt and cause it to block, do it properly in rigid pipe
I have read that the Hepworth equivalants do have a smooth bore...
As will 90 degree elbows on waste pipes :roll: instead of 92 degree swept bends :idea:
Multikwik do the Multiflex adjustable bends, infinitely variable between 0 and 90 degrees (90 and 180 if you like), but they are compression.
