440Cdi, replace comfort programmer with nest
22 Jan 2009
Aberdeenshire
Just moved into a house with 5 or so year old 440Cdi with a Comfort dual channel programmer but no thermostat.
I would like to add a nest thermostat and understand the wiring requirements, but wonder if someone can clarify what to do with the old programmer.
I assumed it should be disconnected as the nest takes over heating control and it's not needed for hot water?
As it's uses built in contacts rather than a ribbon cable I can't just disconnect it and removing it would leave a gap that would need a blanking panel re-fitted?
So to summarise:
Do I fully disconnect the comfort programmer?
Can you buy a replacement blanking panel if I remove it?
Thanks in advance.
