480w dimmer?
  • Thread starter Thread starter dm999
  • Start date Start date
D
dm999
Great site here, I've already picked up a few wiring tips - thanks!
I'm now looking for a 'brass' Georgian style dimmer for a chandelier running 12 x 40w bulbs but all the diy shops seem to sell dimmers for 450w.
Does anyone know where I can get one that will cope with 480w?
Thanks,
dm
dm999 said:
Thanks,
dm
1: chances are, youll need to 1/2 the rating of dimmer, so youll need 960W.
and
2: why the hell do you need 480W of light?
You'll be lucky to find anything like that outside of a theatre...
Hi there, I had a similar problem and found this on TLC's website that may be of use to you. They claim "Our dimmers have been re-rated for GU10 Lamps and are able to dim GU10 lamps to the wattage stated on the dimmer". FOR SOME OF THEM ONLY.
http://www.tlc-direct.co.uk/Technical/DataSheets/Systems/DimmerGuide.htm
They solved my problem and unlike the exisiting dimmer (too low a rating) that was installed when I fitted the new lights all is well. I had (until then) not appricated the need to de-rate a dimmer for certain bulb types.
This link is similar in design (not style to what I ordered) http://www.tlc-direct.co.uk/Products/VLIG1701.html and had been fine (plus you can use the TV remote to dim the lights - now that is lazy!).
Hope it helps.
:lol: just moved home so have inherited the light!
Was thinking of replacing some of the 40w bulbs with 25w so I could use the 450w dimmer. I'd have it on fairly low-light so aesthetically differing wattage bulbs wouldn't concern me, I just don't know if this is a safe/practical solution?
Thanks to everybody for their help.
dm
