J
jg321
Hi all,
As a follow-up from:
https://www.diynot.com/diy/threads/home-wiring-a-mess-help.485966/
where I stated that I'd get some 4mm T&E to practice with, it's arrived, so I thought I'd give an update.
It certainly is more flexible that I imagined, not much larger overall than 2.5mm (presumably helped by the 1.5mm CPC), and seems to just as comfortably fit through a 20mm grommet. However, the less than positive things I've noticed:
1. The Hager double socket I was using to terminate it into could only fit the 2x 4mm cores, so no additional branches from existing sockets.
2. I could only find a 35mm double backbox, and even with the extra space it was a bit more of a challenge to manoeuvre the socket into place - although a large part of this was probably that the backbox was just loose in my hand - I'll try again with it fixed into place.
3. As a DIYer, I've found single sockets and 25mm backboxes to be a bit of a pain with 2x 2.5mm - so I can't even imagine 2x 4mm! I do have spare single sockets and boxes, so I'll fix some of these up in the shed as above, to see how things go.
4. I've also noticed that it's generally a lot less available, although that's probably less of an issue for professionals as I assume most wholesalers have it.
Overall I'm glad I experimented, but given the lower demand on socket circuits these days (kitchens excepted!), in my (inexperienced) opinion, 20A (or whatever is appropriate) 2.5mm radials, or 32A 2.5mm rings seem to be a good option.
Appreciate that most of you will find all this a bit "yawn" - but for the overly-interested DIYer such as myself, I hope this has been slightly useful.
Cheers,
Jon
Cheers,
Jon
