Hi, just moved into an 1830's cottage and have found what could be a massive / expensive issue. It appears that the 2 bedrooms in the loft fall foul of many regs.
Please confirm that my thinking is correct on the following non compliance with regs :-
We intended to actually use these as bedrooms - please confirm that my thinking is correct and that we can't legally use them as bedrooms until these issues are fixed ?.
Thanks so much in advance.
- Floor joists are 6 x 2 - I believe they should be at least 8 x 2 (for 4m spans)
- No smoke alarms or fire doors on this floor
- Side windows are about 600mm up from the eaves - should be at least 1700mm
- The roof appears to be insulated mainly by 50mm insulation backed plaster board on the top but I don't know what is behind it yet so this may be non compliant too
- There is a dormer window in each room which seems ok, but do they need to be a 45mm opening for fire escape purposes ? - I'll need to measure up and check if this is still a reg
- No heating on this floor but I intend to extend the central heating system and install some rads - gas boiler is 100k BTU which in theory should be ok ?
