5 lever locking system
17 Jul 2006
Sheffield
both my front and back doors are giving me the same problem. when i lift the door handle the 5 lever locking system will not engage (the locks do not move). The key will only turn partially in the lock and it only just engages the main lock; however because the key does not turn fully I am unable to remove the key from the lock. What is the best option? is the lock esy to repair? :( :(
See other threads on the same topic - likely to be the door has dropped and the mechanism is not engaging in the corresponding frame strikes. If the door locks when open, and all the hooks etc move - then this is your problem. If not, then the mechanism is knackered and needs replacing. Either get a locksmith to do it, or take a look at some of the internet sites that sell to the public e.g. www.multipointlocks.co.uk
breezer said:
try it with the door open, if it works door has dropped
This works sometimes with older doors but a lot of newer doors have locks which are designed not to engage when the door is in the open position. This is to protect the locking mechanism from damage just in case someone decides to slam the door shut and bend the shoot bolts.
