I've seen online people recommending tightly packing in insulation and others saying leaving a little gap especially on the shower/wet walls.
Stud walls only 80mm so have bought 50mm but now wondering whether I should have got 100mm and either jam or in or trim it
1) for thermal insulation, if you pack 100mm into a 50mm gap, you have 50mm of insulation, not 100mm
2) you seem to be talking about insulation between two heated rooms, so you mean sound insulation,
3) sound insulation is mostly proportional to the weight/density of the barrier, hence the batts are much more solid. You must have no gaps or thin bits. Two layers of plasterboard will add to the sound barrier.
4) interstitial condensation can occur in porous materials if there is not a vapour barrier on the warm/steamy side to prevent the water vapour penetrating
