Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
We had our central heating installed last month and as far as we could tell all 6 were working. However, tonight I noticed the one in my sons room is not getting hot, even though the other 5 are roasting. What could be causing this? Thanks!
Combi Boiler, I believe it is a sealed system. at correct pressure.
The rad was getting hot a few weeks ago and the kids havent been complaining of being cold at night, only checked tonight because of these gale force winds and I noticed it was a bit colder upstairs.
The rad has a valve on it with the numbers 1-5 and it is on 5. My rad which is closest to the boiler was on 2-3 and i turned mine up thinking maybe I was staving off flow to theirs which is next.
rads were all bled and hot less than a month ago, totally new system installed on the 7th of Dec
Fixed! It was that lock valve. Kids must have turned it when they thought I meant for them to turn the numbers down. I put the heat back on and it went hot straight away, funny thing is, now the entire house (downstairs) seems warmer now that that rad is going.
