600 watts (on no load) - lighting circuit
21 Feb 2009
An "interesting" one today... lighting circuit, everything turned off, (on all circuits and disconnected) but 85 Ohms L to N resistance, (thats 600 Watts), tested again with power on and verified by LED "blicks" on meter... thats the entire lighting circuit "on" - but NOT
What can the "load" be?
wiring is a bit of "spaghetti" in the loft
confused...
Is this anything to do with your 'borrowed neutral' in your other post? Have you confirmed polarity/switched line conductors etc?
what do u mean by circuit switched off? actually switched off the MCB or just switched the lights off?
could be transformers if your using 12v lights, could be smoke alarms if on same circuit, same again with bathroom/kitchen fans
MCB off, no 12V lights etc.. smoke alarms run off 9V batteries
fans ... will check - yes there is one in the lighting circuit, I'll disconnect and re-check - borrowed neutrals, - another issue
yes it was the fan, but will run further tests tomorrow, strangely it went down to 35 Ohms, but when disconnected was 100 K Ohms +
it's definitely switching the phase (live) - just checked (on the "problem" upstairs hall light)
Just keep on doing electrical work for profitable gain without qualification/competancy.
I'll find out what odds ladbrokes are offering on you getting sued for completing unsafe electrical installations.
How much public liability is it generally accepted as being the minimum for a domestic electrician?*
*I do commercial and domestic, and do PIR's, which generally need Professional Indemnity insurance, guess how much my cover is, and how much I pay a year.
I'd go for £1M... Directline in the Uk are quite good, about 15 -25 £ GBP / month
(do I need to insure that the electrons flow, or do not flow.. or what..??!!)
I'll leave this for other forum member to comment on when they awake later, I'll let you know what the minimum is, and what mine is later.
Ok, that'll be interesting, perhaps 1.5 £M GBP, and I'd guess that your Comprehensive cover is 5 x this amount (£100/m) .. but I'd really like to know...., it would be interesting to know "what it really costs" in the UK
http://www.browse.to.it/dl.jpg
