John. While I can understand you arguement for not having a bath/sink switch on an E7 system, it doesn't really apply here because:
1. This setup isn't on E7 so it doesn't matter if it was left on 'Sink / upper'
2. Both heaters are the same size.
In fact one could leave it on Sink, to get some economy out of the system if the op was living alone. And should they want a bath, could switch it to bath!
Simon, cleaver idea about using the stat output.
I expect those shower priority switches cost £100, so the OP would not save £100 in electricity having one.
But if a cheap relay system were available it would be interesting to consider. (but probably not very economical on electricity)
The options I see are.
1) A dual or 32A supply to the tank area
2) A sink/bath change over switch
3) 2 dual pole switches, with a simple label saying don't turn both on at the same time. (I guess the MCB would trip and be annoying) These fed from a timer or 1 fed from a timer and one as backup
4) A timer with boost function. The timer feeding one element and the boost feeding the other. This could be connected either way round.
These are the ones I like.
https://www.tlc-direct.co.uk/Products/SMTRTM7.html
and won't allow both elements on together
The way I see it, for the cost of a switch, it would be a great shame not to have the ability to turn the 2nd one on, if the normal one fails
