Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Au contraire. Your mention of 5mm gaps for a floor deck and 3mm and 4mm gaps for a roof deck and frame sheathing is quite a bombshell after all these years of me following what I'd assumed to be standard industry practice and butting these boards together.
This major revelation needs further investigation and clarification, would you like to "expand" on this bombshell requirement?
You mean the video provided by the plywood manufacturer about how to fit their own plywood? but I guess you know better than one of the UKs leading board suppliers....
Poster20,
Stop ducking the questions I asked you - and the simple statements I made about your lack of knowledge.
Wheres your response?
Remember the dry rot mushroom rubbish you advised nonsense that could have cost the OP thousands - are you going to run away again? You fled, disappeared for months so I'm told?
OMG, are you saying that you place blind faith in a video because its been made by a well known name?
Have you ever heard of Thames Water or the massive company that still supplies death dealing insulation?
There are many more examples of big companies talking rubbish - one would think that you would know.
Problem is, when you don't install products as per the guidance set out by the technical department of the manufacturer, it typically voids any warranty on them.
Fairly binary choice; follow the instructions as per the well funded and researched design team of the manufacturer, or the instructions of a little known and, on occasion demonstrably incorrect, anonymous person on the internet?
My key point here is that the manufacturer offers a performance guarantee when I install their products as they say. What equivalent performance guarantee do you offer me if I install their products as you say?
correct answer every time - and should be the answer more often promoted on the forums. Every single manufacturer of anything will provide installation instructions for their products, and that is always the correct method.
Although technically it's correct to leave a 2mm gap, it's already down now. Most chippies don't bother when doing floors, as provided the ply is acclimatised and well fixed the amount of expansion is relatively small. It's obviously a bit quicker to just butt joint it.
In the USA when doing roofs and walls it's a bit different as the climate is more extreme over there. Some of them still butt joint it and take a chance because of the fact on a long run you it throws them off with the rafter of stud spacing and you need to keep cutting.
However, technically an expansion joint is correct.
In my early 20's I worked in the USA for a few years. In California it's not the best place for brickwork, so occasionally I did work with other trades. Back then the chippies were not using T&G for roofs or walls, so unless the framers allowed for 1/8inch gap it meant taking 3/8inch off every 3rd board to keep lined up. Maybe things have changed nowadays.
