1st post so be gentle with me, i have used the forum search facility but can't find a specific answer to my question, so thought i would post it, i have just moved house and the house elecs were check by an electrician (arranged by the seller), who amongst other things said the shower cable isn't big enough and needs renewing (it's 6.0mm and needs to be 10.0mm) as it's feeding a 9.5kw shower, the seller has been quoted £200 to have it replace, but is reluctant to have it done as he says "it works perfectly and has never tripped out". i have asked some of the sparks at work and came up with conflicting answers, but going off what they asked me i have come up with some information, the cable run is approx 12mtrs in plaster and through the attic, it goes into a 45a pull switch, and comes from a modern split load consumer unit fed via a 40a mcb and 80a 30ma rcd.
My question or rather questions are- is it safe ? will it continue to be safe ? is it working correctly ? will it continue to work correctly ?
Thanks,
In anticipation of your answers.
Paul.
Thanks,
Paul.
