9" skirting board please help!!
11 Feb 2007
Please help!!!
Does anyone know of an online store, (or any store for that matter) that sells a 9" skirting board, it can't be 9" made up of of a 7 + 2, it must be a 9 beacuse of the gap between the floor and the plaster.
Any help anyone could offer would be greatly appreciated.
Regards
Mark
you glue the parts together so they act as one
dont forget you loose around 6mm per bit of wood so you will finnish up at either 8 1/2 or 9 1/2" finnished sizes
Big All,
Thanks for that, but because of the gap I have to fill I cant join two sizes together my joiner has basically refused to do that and wants me to get a 9" board.
Mark
its standard practice to glue two bits together
the only possible problem is if the woods a different thickness !!!
9" isnt advisable as its likley to cup :roll:
what profile you after !!!
Mark - how thick, moulding at the top or plain, will they be painted or left natural?
You can get 225mm or 8.8" (nominal, so in reality will be say 5mm smaller) x 22, 25, 32mm thick, also available is 275mm or 10.8" (nominal) x 32mm; obviously got from a decent timber merchant.
So your solution is to go for 275mm x 32mm, get the timber yard reduce the thickness in their planer/thicknesser to what you need, the width reduced on their table saw. To avoid big-all's cupping problem get the rear face of the boards grooved length-wise.
Of course, if they're going to be painted then one option is to use MDF cut to size.
