900mm Flexihose 10mm bore
15 Mar 2006
Tyne and Wear
Hi
Will this 10mm bore flexihose (its the only one i can find with the 900mm length), be any good for using on a bath, just as these will be ideal for the situation ive got or will the water flow be useless
I have a combi so waterflow its great when using the hot water anyway filling the bath, the cold wont be a problem
Your thoughts please
Kev
It WILL reduce your flow and you will have to wait longer for the bath to fill.
Try it and report back your thoughts. :D
can't you use a length of plastic pipe instead?
Flexi's this long are a bit of a joke.
