900mm gas hob above 1000mm drawer unit install
11 Feb 2024
Hi all,
Have a 900mm gas hob that I need to install on a 1000mm set of pan drawers. But as I see it, the width of the hob means I would have to cut out most of the support at the front of the unit to be able to fit it in because of it's depth. Have a 20mm work surface which is easy enough to cut, but I don't see what will provide any structural integrity to the 1000mm unit or indeed the worktop if I have to cut out a large part of the top of the unit frame? Must be an obvious solution, but I cannot see it. Help appreciated.
