Is an RCBO not an RCD (and MCB in a single package)?A 30mA RCD is designed to disconnect within 0.04 seconds at 150mA
Will it always disconnect?
What about an RCBO?
What about an RCBO?
As we cannot do both we have to choose the likeliest scenario for maximum safety which is not to bond non-extraneous metal parts - whether they be spoons or emotive sounding objects like sinks or baths.
I think - hope - you would agree that the latter is more likely and therefore would also agree that it is advisable not to bond isolated metal objects i.e. those which are not extraneous conductive parts.
When there are 'swings and roundabouts', such that a compromise is necessary, (s)he who wants to take a balanced approach has to acknowledge the arguments in both directions.I may be stating the obvious but you seem to be arguing both ways.
Indeed, that's what one has to do whenever there are swings and roundabouts.I As we cannot do both we have to choose the likeliest scenario for maximum safety ....
I don't think one can generalise. One has to make a balanced judgment on a case-by-case basis.... which is not to bond non-extraneous metal parts - whether they be spoons or emotive sounding objects like sinks or baths.
I'd say the opposite re the bath, if it is fed by plastic pipes and deemed not an extraneous conductive part by any other means then I fail to see how bonding it will make it safer.
Re the extension lead, if someone is daft enough to run one into their bath and drop it then it is their stupid act that caused the problem, not that of the electrical installation.
A reasonable move towards ensuring that happens is underway, to be implemented in 2012 as I understand it.
Can you elaborate on this please?
True - but, as I said, one needs to make a case-by-case judgement as to which of the approaches is safer. A good electrician should do that on the basis of all considerations (including possible consumer stupidity), and not wash his/her hands of possibilities which are not the fault of the electrical installation.Re the extension lead, if someone is daft enough to run one into their bath and drop it then it is their stupid act that caused the problem, not that of the electrical installation.
with a sound understanding of electrical principles.
I disagree totally, making something that is electrically floating earthy can make it worse.In the specific bath scenario I described, there is zero risk due to the electrical installation (doesn't get anywherte near the bath). If there is a risk due to user stupidity, no matter how small, that surely shifts the risk-benefit balance in favour of bonding ('extremely small' is still greater than zero) - in that specific situation.
I find it rather worrying that with all this extra regulation, talk of initiatives to improve things soon, and so on there are so many people who have gone through "the system" and yet lack an understanding of things such as earthing and bonding principles which were well established and understood half a century ago.
No, that was my point about arguing both ways. You cannot plan for both.In the specific bath scenario I described, there is zero risk due to the electrical installation (doesn't get anywherte near the bath). If there is a risk due to user stupidity, no matter how small, that surely shifts the risk-benefit balance in favour of bonding ('extremely small' is still greater than zero) - in that specific situation.
As I keep saying, it is necessary to think about the specific scenario, not just generalise.
The 17th edn OSG simply says supplementary bonding is not required to metallic parts supplied by plastic pipes (4.7)
