Hi all,
Getting to the final stages of my shower room refurb and just wanted to check a couple of things if I may with the experts on here.
Firstly, I have just finished tiling and grouting the shower splashback areas so next step is to install the shower enclosure. Therefore, I need to seal between the tray and bottom tile before I do this, I believe. Ordinarily I'd silicone using a fugi tool and thus a 45 degree angle profile but guess I don't want to do this as this then won't sit neatly behind my aluminium box wall profile thing that the screen slots into? Therefore do I just silicone in the gap as much as possible, then once all installed do a second silicone bead around the bottom of the tile and tray, up to the now installed aluminium wall profile using the fugi tool?
Secondly I have a thermostatic shower valve which has compression olive fittings. The instructions specifically state not to use any kind of sealing compound or PTFE tape. To be honest, I use fernox LSX on all of the compression fittings I've done. Will this cause any issues or is there a reason why these compression fittings don't require it?
If it helps, I've added some photos of my tray/bottom row of tiles, my shower valve that I purchased and the type of enclosure I have to fit.
