Hi Everyone,
This might be a challenge. I brought a flat a few months back which was the same as my old one (just a floor up).
Now the flat is 4 years old eco build (so there is only one boiler for all flats) and there a 3 small radiators.
When turning the heating on usually there is a control panel, you flick it up until the flames comes on and hey presto, hot water is released and you have heating. (this is my old flat)
But i turn this control panel on yesterday for the first time since moving in and the flame went on and nothing........ The thermostatic valves were off so i turn them on - great we got heat. After an hour i turn the heating off via the control panel and thought that was the end of it.
A few hours later i realized that the radiators were still on, checked the panel they were off?? so i used the valves and turned them manually off. This morning i didn't touch the panel but just turned the valve round and the radiators came on.
It seem the panel does absolutely nothing to control the actual inlet, and i cant go on turning the valves on and off to control the temp in my flat. Not sure who i should call or how to explain the fault. Understandably i'm confused :/
Please someone help!
