I've spoken to an electrician about some work that I need doing in the kitchen.
In the area requiring work, there are currently two double sockets and an oven socket.
The cables themselves are all up to regs, according to the electrician, but the oven needs moving, and one of the sockets needs moving, in addition the cable from the first socket to the second socket is not chased in (just clipped under the worktop).
The CU is in the garage directly behind the kitchen wall and all of the cables run up to bedroom above the kitchen and then down into the kitchen. He reckons that the oven circuit is RCD protected (although, to my untrained eye, the labeling suggests that it isn't). The new oven seems to be 20A.
So, what is required is chasing for the two double sockets and the oven socket, and the oven outlet plate, cabling and installation of those sockets, plus connecting up the oven, and disconnection of cables as needed.
The electrician said that the existing cables are OK but suggested new ones as part of the work.
He reckons that first fix is a day's work and second fix another half day (I suggested that I could chase, but he said that it was only an hour's work for him).
On the face of it, that seems an excessive amount of time for the work, but perhaps there's lots of less obvious stuff that needs doing.
Just wondered if anybody here had any thoughts.
