While trying to work out the logic of why rings were devised post war:
Surely, rings only saved copper if the distance between..the last socket and the CU (or fuse board as it would have been then) was dramatically shorter than the trip out to it?
Which got me wondering - would it not save more copper to split the ring in a sensible place (longest socket-socket bridge, farthest from the CU) and save that leg of copper instead - have 2 radials? Or is that the situation where those 2 radials would for sure have had to go in in 4mm2, and for the cost of joining the radials to form a ring, 2.5mm could be used, so yes, more copper is used than 2x 2.5mm radials, but less copper is used than 2x 4mm radials?
Next q:
My TF company are recommending a "service void" - I understand the reasoning but it seems like a large amount of room to lose for the convenience of easily running a few cables in some small percentage of the volume created by the void. Sure I could fill most the void up with insulation and then it have a practical benefit, but might it just be better to chase a route into the celotex that will line the house inner, put an oval duct in it, and run the cables in that? (the air tightness membrane would go on the outside(world) side of the duct rather than having the duct come through the AT membrane
Suppose I do go for a service void; the tf co are advising the battens to form it run vertically. This means for ease of reaching a socket the wires would circulate in the gf ceiling/ff floor void (there is no gf floor void unless I duct the gf screed) and drop down the walls to sockets on the ground floor? Isn't this incredibly wasteful on wire to have to loop down the wall and back up it for every socket? Might it be better to make the service void have horizontal runs of battens at socket height and just run the electrical wiring horizontally around the room to each socket? The SV can have vertical battens everywhere else no probs (and it helps pinch the air tightness membrane glue joints) but socket height and wall lamp height (SWMBO hates overhead lights) the sv would be better horizontal, yes?
I've long wondered why, when wires visit each socket i9n turn, are the conductors cut through? Physics lessons of old told me that resistance occurs at a surface, so would it be better in volt drop terms if the wire that came into the back of a socket was continuous with the wire that left - fold it, strip it and poke the folded bit into the terminals of the socket, but don't cut it. I'm guessing theyre cut because overall the contribution to voltage drop is minimal, but the inconvenience of trying to neatly strip insulation off a wire that hasn't been cut through is high and would slow installation considerably?
Next q:
