A home phone through a mobile network router?
27 Jan 2010
Buckinghamshire, Darn Sarf
Some time ago I ditched my £30 a month phone and broadband deal, bought a ZTE286D router and fitted it with a £5 per month SIM from Smarty. I believe they use the O2 network. It worked, and still works, very well,
I noticed it had a (RJ11?) phone port so I connected my old home phone to it. To my surprise my first call (to my mobile phone) connected, and I was able to talk to myself, however the next call was disconnected soon after the calling phone started ringing. I can still, to this day, call this router's number from my mobile phone, just like calling any other mobile phone, however the phone doesn't ring and the call goes straight to voicemail, similar to what happens if that mobile phone is in a signal blackspot.
The simple questions, with hopefully simple answers, are as follows. My goal is to have the equivalent of a mobile phone on the hall table, but without the cost of a landline. I am not a heavy user of data; my current plan with Smarty is for (IIRC) twenty giggle-bytes per month.
1. Do I need VoIP credentials in order to use this router as the basis for a home phone?
2. Do I need to pay a monthly subscription? If so what do I ask for and who do I ask? Smarty? ZTE?
MM
I’m not au fait with much, but maybe, rather than use the old landline connection (probably why it was disconnected) maybe enable WiFi calling?
I think that only enables mobile calls rather than to/from a landline number. Like you I'm not that genned up on that sort of thing so don't know a way round the problem
Nothing to stop you using a 3rd party VOIP provider - it doesn't care that you're accessing the internet over a mobile network. A club I belong to has 3 5G broadband internet access (having be totally let down by Openreach) and is running a Phonely VOIP service over it perfectly well.
I have had VOIP phones, and also used Whatsapp, and each seems to have some good and bad points, the main thing seems to be the ability to make a call to the electric provider to tell them the supply has failed.
I have a wired phone for emergency use, and if I loose the copper landline, I will need to look at some sort of battery back-up.
In the main the mobile works well. Did have some high winds a couple of years ago which caused the central heating to fail, when it took out the local mobile phone mast. I have now stopped using geo-fencing.
Wife and I use different service providers, so we hope one phone will work, but walked up the street to the phone box, to find it is a defibrillator store, and you need a mobile phone to get access. Walked in opposite direction and found phone box was a book swap. When the railway is running their radio repeater may connect us to next town, never tried it as technically not legal, but it seems we rely on the mobiles working now.
First thought is what sort of package you got with the SIM - i.e. does it actually support voice calls ?
I'd also be logging into the router and looking at the settings.
Also, try the SIM in a phone and see if you can make/receive calls - that'll help narrow down between SIM/account problem or router proble..
