Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
What would be a true effect or what could realistically happen if no corrosion inhibitor is added to a central heating / primary circuit after draining down a system? Is it worth buying? If so what are the best types to go for?
it will corrode, fill up with sludge, the pump will wear out from sediment, the boiler will bang and kettle, the radiators will fill up with gas and sediment, and eventually the radiators will get holes and start to leak. This may happen before or after the sludge blocks the pipes and the system stops working.
