    Dismiss Notice
A New Bit of Kit (well in our box anyway)
Discussion in 'Electrics UK' started by westie101, 18 May 2015.
  1. westie101
    westie101
    3 Jan 2011
    2,497
    Thanks Received:
    313
    Cumberland
    Country:
  2. Sponsored Links
  3. westie101
    westie101
    3 Jan 2011
    2,497
    Thanks Received:
    313
    Cumberland
    Country:
    Trouble is if we try and use it onto a non RCD protected house that has a fault that keeps tripping the device.
    That could be interesting!
  4. Taylortwocities
    Taylortwocities
    28 Jul 2006
    20,044
    Thanks Received:
    2,061
    Oxfordshire
    Country:
    Yes, they'd have to ask the neighbour to reset the RCD!
    PS Does the Restore plastic box meet the new requirements for fireproof enclosures?
    :mrgreen:
  5. westie101
    westie101
    3 Jan 2011
    2,497
    Thanks Received:
    313
    Cumberland
    Country:
    It'll be sealed if for no other reason to prevent the neighbour switching it off
    Er, well, um, nope! :LOL:
    On that subject don't expect to suddenly see hords of metal cut-outs or meters coming into use, they can be a bigger safety risk than not!
  6. SimonH2
    SimonH2
    4 Nov 2010
    5,707
    Thanks Received:
    579
    Cumbria
    Country:
    Hmm, looks like a plastic box, RCBO, and a length of cable. Bet it costs more than that shopping list !
    Have the rules changed then ? Before I was interested in such things, we had a fault at home - and for a while we had a supply from next door. AFAICT from things my dad said when it came up, they just installed a pair of cables from next door's cutout.
  7. ericmark
    ericmark
    27 Jan 2008
    17,436
    Thanks Received:
    1,614
    Llanfair Caereinion, Nr Welshpool
    Country:
    I see the point in current limit of 40A just to keep everything running but the RCD at 30 mA is just asking for problems.
    We have all seen where we fit new consumer units and the RCD will not hold in on one circuit having one for all circuits you will be visiting every 5 minutes to reset the RCD.
  8. Taylortwocities
    Taylortwocities
    28 Jul 2006
    20,044
    Thanks Received:
    2,061
    Oxfordshire
    Country:
    We know, and there have been representations to advise on the additional risks of this new reg. At the moment, that's what we have got.
  9. ibruceuk
    ibruceuk
    11 Jun 2005
    185
    Thanks Received:
    17
    Lancashire
    Country:
    My MIL had a supply outage due to damaged cable under the house and the engineer dragged a genny out of the van and length of SY cable with RCD etc. Connected it all up and the RCD kept tripping as the original installation had no RCD and clearly a fault. Ended up just a trailing socket with a 4way for the freezer, boiler and couple of lights.
  10. Sponsored Links
  11. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,783
    Thanks Received:
    2,857
    London
    Country:
    Why does the box need to have an RCD in it in the first place?
  12. securespark
    securespark
    11 Jan 2004
    36,079
    Thanks Received:
    1,206
    Country:
    My house has an RCD incomer which I inherited. It was fitted in 1992. It tests out fine (Hager) and has only ever tripped due to known faults (flood under floor saturating junction box and faulty tumble drier element).
  13. securespark
    securespark
    11 Jan 2004
    36,079
    Thanks Received:
    1,206
    Country:
    To protect a temporary installation of a trailing cable at risk of potential damage.
  14. plugwash
    plugwash
    28 Mar 2004
    9,303
    Thanks Received:
    330
    Country:
    I can think of a few reasons.
    1: introducing a long (25m in the default kit but they say extensions are available) extra peice of relatively thin cable (6mm, presumablly chosen so the size/weight is managable) will make the EFLI higher, this may mean that overcurrent protection devices no longer provide adequate earth fault protection.
    2: the default cable appears to be un-armoured (again presumablly to keep the size/weight managble, they say a braided cable is available as an option too) and is likely to be routed in a less than ideal manner. RCD protection seems a reasonable precaution to reduce the danger in the event of damage to said cable.
    3: the kit may sometimes be used on TT setups where overcurrent protective devices are incapabale of providing earth fault protection so a RCD at the origin is needed.
  15. Adam_151
    Adam_151
    17 Jun 2004
    6,642
    Thanks Received:
    267
    Country:
    It would be good to see a bypass on the RCD, so the supply authority chap could, if the RCD wont hold, make a judgement call about whether to bypass it or to give householder a temporary board with a few sockets on it
  16. JohnW2
    JohnW2
    28 Jan 2011
    46,371
    Thanks Received:
    2,996
    Buckinghamshire
    Country:
    Do I take it that you can see both pages/'sides' of the brochure? I can only see the first page/side, the second being blank.
    Kind Regards, John
  17. Iggifer
    Iggifer
    8 Sep 2011
    4,637
    Thanks Received:
    587
    Warwickshire
    Country:
    Specification
    Cable Length
    25m of 3 core 6mm2
    H07RNF Double insulated 9 kg (25 metres) Braided/shielded cable is an option
    Operating temperature range
    -20 to +85°C
    Enclosure
    170 x 100 x 210mm IP54
    Weight
    1 kg
    Temperature
    -20 to +50°C
    Rated voltage
    240V
    Rated load current
    40 A
    Over current Tripping
    40 A MCB Type B
    Residual current tripping
    30 mA
    Accessories
    10m extension available
    • Thanks Thanks x 1
Loading...
Share This Page
