Hi All,
Just moved into a new house and am thinking about replacing my rewirable fuses with MCBs and here looks like a great place to ask! Here's a photo of the fusebox and a couple of fuses which I took out:
As you can see, the 30A (cooker) fuse has already been switched to MCB type. As far as I can see, I should be ok to swap the old ones over with these:
http://www.tlc-direct.co.uk/Manufacturers/Wylex/Wylex_Standard_Range/index.html
If really necessary, I'll replace the whole thing, but I'm well aware that just because it's old, doesn't mean it isn't safe. I would like to change them because a) it's much quicker to flick a switch than to rewire a fuse b) I understand MCBs should trip quicker than fusewire (so they could be slightly safer).
Any comments or advice would be appreciated!
Thanks, Ed.
Thanks, Ed.
