- Joined
- 11 Jan 2004
- Messages
- 47,182
- Reaction score
- 4,134
- Country
If you just want to centralise the shower head, just buy a longer hose.
There is no specific amount of pressure that is required, it depends on the shower valve fitted and what kind of shower you want. Some will work as low as 0.1 bar.How much pressure is required to not need a pump?
That arrangement will not work - hot and cold must be at the same pressure, so hot from the cylinder and a separate cold from the cold water tank in the loft.I only ask because there are signs that there was previously some form of mixer shower feed from the hot water 22mm pipe and the mains cold water 15mm pipe.
Not an option. Currently I have a deluge head with separate smaller spray. The current control unit is right where I need to put the shower head attachment. I could leave it where it was, but it will be a good 4 inches off centre of the new shower area, defeating the object of a wider shower area as I'll still be as close to one of the walls as I was before.If you just want to centralise the shower head, just buy a longer hose.
However if this bathroom is upstairs and the cold water storage is in the loft directly above, any non-pumped shower will be dismal at best.
Part P (in fact all of the Building Regulations) applies to any work whatsoever on fixed electrical cables or fixed electrical equipment located on the consumer’s side of the electricity supply meter which operate at low or extra-low voltage and are—My colleague thinks this is OK to DIY, but I'm certain this requires part P (whereas simply replacing like for like does not).
What is the capacity of your HW cylinder, how many people take showers over what period of time, and how long do they like to be in there?My central heating is open vented, NOT combi.
Capacity - unknown. The cylinder is about 4 foot tall, I think.What is the capacity of your HW cylinder, how many people take showers over what period of time, and how long do they like to be in there?My central heating is open vented, NOT combi.
I shower, the wife doesn't. It's only us. I take my time.
When the pump pulls from the top outlet of the cylinder, there is a chance the pump will pull water quicker than it can be replenished, and suck air in from the vent pipe instead. This is why an Essex flange is recommended, so the pump is pulling from lower down. A Surrey flange can be used, which replaces the top cylinder connection, and has a long tube down into the tank, giving two outlets, one for the house, one for the shower. Reduced flow on both though.
2 questions.
Can I use the existing (6mm²) wiring (changing the fuse at the consumer unit to 13A) to supply the built in pump of a power shower? If yes, is this notifiable or is it akin to replacing one electric shower with another?
How dismal is dismal for a non pumped mixer shower, compared to a 7.5kW or 8.5kW mains fed electric shower. It might be an option for me to plumb in a straight mixer as a temporary measure with a view to adding a pump at a later date.
With that last comment in place - how effective is Mira's "magniflo" that claims up to 3x more flow than a standard mixer?
Finally, for the pipe work, if fitting a mixer/power - plastic or copper?
(a) in or attached to a dwelling;
(b) in the common parts of a building serving one or more dwellings, but excluding power supplies to lifts;
(c) in a building that receives its electricity from a source located within or shared with a dwelling; or
(d) in a garden or in or on land associated with a building where the electricity is from a source located within or shared with a dwelling.
Sounds like a Q for the plumbing forum. Good luckWith that last comment in place - how effective is Mira's "magniflo" that claims up to 3x more flow than a standard mixer?
I would say copper. With soldered joints.Finally, for the pipe work, if fitting a mixer/power - plastic or copper?
