Hi there.
I'm working on a pretty large project at the moment. There's one part of the project that is absolutely doing my nut in. I have a large MDF floor base, approx 50mm thickness, of which I want to clamp two protruding structures, that a handle can be screwed to.
It's kind of hard to describe, so maybe this picture will help. Those two protruding structures are what I hope to clamp the handlebars to. My problem really is deciding on exactly how I'm going to model these structures.
As the handles are designed to take a persons weight, they will be pushed back and forth a bit. Since the height of the handles must be at around 1 metre, I can see this causing a lot of leverage, and ripping straight through the MDF.
I need a good solid method to stop these from buckling under a lever like mass.
At this point, I'm thinking of building a support structure with threaded inserts of some description.
My apologies for a vague post, I'm not really looking for someone to do all my work for me, I'm just not all too sure where to even start researching for weight bearing structures!
