    Dismiss Notice
About to install a real wood floor on a sub floor
Discussion in 'Floors, Stairs and Lofts' started by Tred_Bloke, 30 Jun 2009.
  1. Tred_Bloke
    Tred_Bloke
    30 Jun 2009
    9
    Thanks Received:
    Gwent
    Country:
    I'm really concerned in case it has to come back up for any reason.
    Carpenter say glueing it down is the way forward.
    Gas main is under there, central heating and wiring.
    Is there a preferred method, making it easier to pull back up if necessary?
    I know secret nailing is an option? how about glueing to plyboard?
    Maybe i'm worried about nothing.........
  2. Sponsored Links
  3. will2000
    will2000
    13 Mar 2009
    103
    Thanks Received:
    2
    Glamorgan
    Country:
    why dont you embed a hatch into your floor
  4. mattysupra
    mattysupra
    30 Jan 2007
    2,256
    Thanks Received:
    50
    West Midlands
    Country:
    you should have insurance if there was a problem down the line like water leek,.
  5. WoodYouLike
    WoodYouLike
    14 Nov 2004
    7,710
    Thanks Received:
    215
    Kent
    Country:
    Lets start with the measurements of the wood floor you plan to install (floroboards? if so how wide, thick, long are the boards?)
    Then - how often did you up to this moment have to get to the wires and pipes?
    And like Mattysupra says: get your insurance up to scratch.
  6. Tred_Bloke
    Tred_Bloke
    30 Jun 2009
    9
    Thanks Received:
    Gwent
    Country:
    Sorry the response has been so long, had set my mind on the bonding down method, but now as fitting is imminent, having second thoughts....
    The room measures about 4.5m x 4.5m, new T&G boards will be laid onto pine floorboards which are 170mm wide.
    New T&G boards are 150mm wide and 19mm thick.
  7. WoodYouLike
    WoodYouLike
    14 Nov 2004
    7,710
    Thanks Received:
    215
    Kent
    Country:
    Do you plan to install your new boards in the same direction as the old? Best is to install them perpendicular to avoid effect of any cupped old boards. Is that's not possible (for whatever reason) you first have to install hardboard or even plywood on the existing floorboards.
    Then lay foam underlayment and install your new boards. Our How to glue T&G boards the correct way article might help
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
