ABS warning light
20 Mar 2018
Stoke-on-Trent
I have an old (2004) Mondeo, and a couple of days ago the ABS warning light came on. My first thought was one of the wheel sensing leads had fallen off, but next time I used the car it didn't happen, since then it's been on and off a few times.
It might be one of the connector fittings on a hub loose, I had that once on a new hub. I'll check it when it stops raining, but grateful for any comments.
Have a good look at the reluctor rings on the front driveshafts....excess corrosion can cause them to drop off occasionally :eek:
Failing that, its the wheel sensors (hopefully) or the ABS unit itself at fault.
John :)
