to go back to log from main menu:
Entering Programming Mode
The programming mode is for you to configure the system, and make any changes to the pre-set functions.
If the system is in Disarmed (Alarm off) mode, follow the steps below to enter the programming mode.
1 Press ‘pr’ key on the function key list.
The screen will prompt you to enter the PIN code.
2 Key in your PIN code within 30 seconds.
3 Press (tick) to continue.
message is displayed for 2 seconds.
4 Then the Programming Main Menu will typically be displayed.
5 The following items can be selected:
· Fault log (appears only if there is a fault condition in your system)
· Walk Test
· Devices +/-
· Log
· Adv. Settings
· Tel. Settings
6 After making a selection by moving the cursor to the desired item, press (tick) to confirm the selection. The display will show you the individual programming screen accordingly.
Note
• If a down-arrow symbol appears on the last column of the screen, it indicated the selection list can be scrolled downwards. If the lowest position is reached, the down-arrow symbol disappears.
• If an up-arrow symbol appears on the last column of the screen, it indicated the selection list can be scrolled upwards. If the highest position is reached, the up-arrow symbol disappears.
• Selecting (return button) will return to the Alarm Off screen.
Important Note
• In programming mode, if no key is pressed within 5 minutes, the control panel will automatically exit the programming mode and return to the Alarm Off screen.
