Ac Induction question
9 Mar 2012
Lancashire
hello again,
Im aware of ac induction within Alarm cables, is this something that you would pick up indefinitely if alarm cables are anywere near ac cables.
im only asking because my 8 core alarm cables are all segregated away from ac , other than were i need to take them accross to the Elite 48 panel, they will cross over / under the light switch cable within the wall. the Panel is going to be mounted pretty much were the light switch cable drops down to the light switch in the wall.
would i be ok with a panel filter kit from act, or do i have to re-locate the panel, or light switch cable? or just get everything up and running and test with a multi meter?
Crossing is fine. Induced currents normally happen where cables with heavy loads run side by side with the low voltage alarm cables.
Oh great.. I've done my best to segregate the cables. It is literally as they come into the panel..
Do you think throw a filter in for good measure
