Please excuse the long story but feel I should give you the full story to make it easier to help me with the problems I am having.
I have an Accenta G4 with 2 remote lcd keypads. The system has the following zones wired:
1. Front hall pir
2. Rear hall pir
3. Living room pir
4. Back door contacts
5. Unused and set as unused.
6. Front door contacts
7 & 8 unused and set as unused.
* I have not wired in an external siren yet*
Have made sure all the fitted links to PA, Tamp and TA are fitted.
On powering up the alarm, the alarm sounds and I enter code 1234. to silence alarm. I put the cover on the panel.
On the keypad I get the error message Tamper Fault Lockout.
It does not recognise my 0123 factory set code and stays with the error message.
If I enter 9999 and go into engineer mode & go into walk test it sounds 2 tones an should show all the 8 zones as zeros until I activate it...zone 5, 7 and 8 are showing 1s already, also although the pirs led lights up it does not activate the walk test. The contact zones change when activated but no zones generate a tone at all.
The pirs I have are Guardall PQ15, I have wired as follows:
On pir + to 13v on panel.
On pir - to 0v on panel.
On pir NC alarm to zone on panel.
On pir NC tamper to TAMP on panel.
Any help would be greatly appreciated
1. Front hall pir
2. Rear hall pir
3. Living room pir
