Hi all,
would anyone know the maximum resistance of tamper loop that an accenta mini will work to? I have had a couple of random triggers of of the internal sounders while the alarm hasn't been set, and looking at the log it has been the tamper loop that has triggered it. Resetting the panel clears the issue, so it's not a permanent break, so I was thinking of measuring the resistance of the total loop to see if it is close to the edge. It happened at night a couple of days ago, then again around twenty minutes after resetting it, but has behaved itself since.
Failing that, if anyone has any other suggestions as to the cause?
