Accenta/Optima G3 Intruder Alarm
21 Sep 2012
Alarm has no power lights on panel
Just Stopped
Any suggestions would be appreciated
24 Dec 2008
I suspect the OP would like more help!
Briefly, start by checking the external mains supply is OK. Beyond that the panel will need testing. If opening the panel, turn off mains. If known, enter engineers code, open panel, (without engineers codes, silence bells by entering owners code) and check mains supply, fuses and battery.
Hopefully problem found. Close panel, restore mains and reset.
The engineers manual is available on line and careful reading, understanding and circuit testing will enable you to work through your problem, if it is not a failed battery and fuse.
22 Feb 2011
Humberside
Hmmmm, have you opened a tamper on the system? as these sometimes tend to "play dead" whilst a tamper is open , let us know more info
Thanks MadMan
