Hi Folks,
I moved into a house a bit ago and on entering we put in the alarm code that the estate agent gave us.
To be honest we've not really used the alarm much in a year but recently there's been a spot of burglaries in my area so I'm trying to get tip top by installing some PIR lights, locks on my gates but the main thing is to get the alarm working.
So here goes...
The Alarm we have is a Accentra / Optima G3
Looking at the instructions it looks like a 8SP 401N
https://goo.gl/photos/jqu87BCzrioECCyv6
So I had the tamper button on for a bit, it was due to a decorator unscrewing a screw in hope that they could move a box while they decorated. They didn't move the box and failed. I reset this with some help from the manual.
Next up I thought I'd arm the system.
It didn't sound the alarm box. I rang up the installer who gave me the engineer code. So I went to the instructions and turned to page 22 and tried to do a walkthrough test using the following.
Prog # # # # (Eng Code) 1 2 - Strobe Test. Result = couldn't see a strobe. Pressed Reset Twice
Prog # # # # (Eng Code) 1 3 - Ext Siren (Bell Test). Result = The alarm box sounded once.
I set my alarm and then tested it out to see what was going on.
Result is that the alarm goes off BUT the siren box isn't sounding at all.
Do you think I can fix this myself?
I'm thinking...
Change Battery + Fuses?
Can I get the parts for these and do it myself? Today I've put up junction box + power in loft, PIR LED Light & 4 CCTV cameras up. I'm OK at having a go as long as I know the safety risks.
I was thinking off turning all the electric off in the house via the junction / fuse box.
Then flicking the power off fused spur near the alarm box.
Then taking the cover off and seeing what's what. Ordering any new parts, can I get these locally? I'm close to a Maplins / Screwfix / Toolstation / B&Q.
Then replacing siren box battery too.
Any advice really appreciated. I can do some stuff but I'm no alarm engineer.
Cheers, Ben
So here goes...
I'm thinking...
Cheers, Ben
