Hey guys,
Very quick question...
Does the clamp need to be accessible for inspection as its not a permanent connection?
I had the mega flo moved which was located at the back of the shower (hot and cold supply to the shower was fed from the cupboard housing the megaflo). The earth bonding clamp was attached to one of these copper pipes (probably cold). Now theres nothing there as all the pipework is below the flooring (basin is going here but its all push fit). The earth cable is not long enough to extend to the new megaflo location where I could have re-attached it quite easily.
The installer said to connect it to the pipes in the floor where there would be no access but I'm a little sceptical about this. I might be able to fit it to the flow for the underfloor heating which will be almost directly under the vanity unit so some access could be provided by pulling out the drawer?
