I would like to add a pendant light to a room that has an existing light fixture. The room has one light switch. The house is 140 years old and the wires are not color coded. The switch itself has two wires running into it. I have installed the new light to the ceiling and attached the wiring to the light. The difficulty I'm having is replacing the existing switch with a single unit that has two single pole switches on it. I would like each switch to control each light separately. The new wiring I purchased has a ground wire, white, and black. I have replaced many light fixtures with ease, but I'm needing some help with this. Please help...expalin it to me as you would a child (duh)....
If this is not possible, could I...
1.) Add a new single pole switch to control the new light (again I would need your assistance with the wiring specifics)
or 2.)Convert the wall outlet to a switch and wire the new light into that (again, I would need the specifics)
Thanks!
-Matthew
p.s.....In the USA
Thanks!
-Matthew
p.s.....In the USA
