Adding Ei interconnected smoke/heat alarms to existing.
Errors shows that AI has always to be reviewed
Brown for Permanent Live (L), Blue for Neutral (N), and Grey (oversleeved with black or brown tape to identify as Interconnect) for the IC terminal, with bare copper in green/yellow sleeving for Earth.
When typically 3 core and earth cable colours are Brown, Black, Grey and bare.
That's true, good thing I sleeved the neutral with blue ;)
  • Thanks
Reactions: SFK
Also, I have cut the locking 'tangs' out of all the base stations of my and my parents Ei smoke alarms.
Means my parents and i, when the batteries need changing, can now simply slide the alarm out without having to use a screwdriver to unlock and leaver it.
Good idea, they're a PITA to remove (though mine are mains powered so shouldn't be something in doing regularly.
Having installed and commissioned hundreds of Aico / Ei Electronics systems across domestic and light commercial properties over the past 25 years, a few practical field engineering points that will save you headaches:
1. Baseplate Locking Tangs:
While cutting the locking tangs on the easi-fit base makes removal easier, keep in mind that if building control or a landlord inspection ever inspects it, BS 5839-6 (Grade D1/D2) specifies tamper resistance. You don't actually need to butcher the baseplate or gouge plasterboard with a heavy screwdriver: Aico moulds a dedicated release slot on the front lip. If you slide a small 3mm or 3.5mm terminal driver flat into that horizontal slot and push straight back towards the hinge, the internal locking lever unlatches cleanly with zero levering force and the head unit slides forward effortlessly.
2. Garage Detection & Fire Compartmentation:
Make sure the unit going into the garage is specifically a Class A1 Heat Alarm (e.g. Ei144e or Ei3014), never an optical smoke detector. Vehicle exhaust fumes, cold damp air, and dust will trigger constant nuisance alarms on an optical head.
Also, if running that 3-core & earth into the garage means drilling through the fire compartment wall (typically 12.5mm double plasterboard or blockwork into an attached garage), you are breaching the fire barrier. Any penetrations must be sealed with certified intumescent acoustic mastic to satisfy Part B.
3. The RF Hybrid Alternative (RadioLINK+):
If fishing 3-core & earth past that awkward inaccessible joist into the garage is a nightmare, you don't actually need to pull physical cable to every single point. Aico / Ei systems support hybrid hardwired-RF meshing. If you pop an Ei100MRF (for the 140e series) or Ei3000MRF module into one of your hardwired hall/utility bases, and fit an RF module in the garage base, that single RF bridge will transmit the interconnect trigger across the whole hardwired loop. You just house-code them together (press the house-code button on the RF base until the blue LED flashes, then code the heads).
4. Single Phase & Circuit Isolation:
Ensure that all alarms on that hardwired Interconnect (IC) line are supplied from the exact same phase and circuit. Mixing feeds across different circuits or split RCD boards where neutrals are separate can cause voltage differentials across the IC terminal, which leads to intermittent 3 AM phantom alarms. Always sleeve the grey wire at every base and junction box (with brown or black over-sleeving) so anyone working on it later knows it's the live interconnect trigger, not a neutral.
5. Locate Switch (Ei450):
When you have 4+ interconnected alarms across hall, landing, utility, and garage, if one goes off in the middle of the night, tracking down which unit tripped is chaotic. Consider fitting a battery-powered Ei450 RadioLINK Alarm Controller on the wall in the hall. It gives you a single 'Locate' button that silences all sounders except the originating unit, so you can immediately see which head detected smoke/heat.
Mine are also all mains (exactly same devices as yours.
The Batteries are for backup when mains fails.
The units seems to test the battery every now and again and so the battery power does drop.
I typically change the batteries every two years.
I have once left the batteries for four years, and was rudely awoken as one alarm started going off triggering them all. I thought the alarm was faulty, but it was fixed with a new battery (and I changed all the batteries at same time).
The reason I cut out the tangs, was because a elderly relative had the alarm sound, could not get it off the ceiling, so hit it with a hammer until it stopped. I arrived to find an exposed mains circuit board hanging from ceiling. They had never changed the battery saying it is mains and does not need it. :)
I know age of the batteries because I write installation dates on all the batteries, and on one central smoke alarm input a sticker so I know when to change all the batteries with a simple glance. The sticker also has the 10year alarm renewal date on it as writing on side is too small.
SFK
