I plan to fit patresses. Wire up the sockets so they connect to each other without connecting to to the existing ring. I won't screw in the front plates. I hoped that when an electrician came in he could do the final bits of checking what ive done and connecting the existing sockets to the new ones I've installed. Leaving me to screw in front plates.
I hope that makes a bit more sense. Quite tricky explaining.
Just to check am in permitted to do this myself without a certificate?
I had a lot of hassle with 25mm boxes whilst fitting MK Logic double sockets. The cables were fed in from the bottom. If they were coming from the top I reckon it would have been a lot easier, as the rear of the socket seemed to foul the incoming cables through the bottom corner grommets.
Taking out another 10mm shouldn't be too difficult (depending on the material density), so I would do it!
Got it done..had a friend come over and help whose done this sort of thing before. Used 25mm patresses and they were deep enough. Thanks for all the advise.
Next job....moving twould existing celling lights. .....not sure how complicated that is!! Do I accept my limitations or can this be done myself?
