ADT Alarm problem
11 Nov 2005
Hampshire
My daughter bought a house with a monitored ADT burglar/fire alarm. The monthly cost was more than she could afford so had it disconnected (from being monitored) and used it in unmonitored mode with her owning the hardware.
She had a problem with it about two years ago, got the ADT people in. Seems it just needed a new battery, but it also cost a fortune.
It has gone wrong again. I am not certain but think the display simply went dead without warning. We thought it could be the battery again so it was replaced. The one previously installed was a Yuasa NP7 – 12 12V 7Ah., but she replaced it with a Yuasa NP1.2 – 12V 1.2 Ah. Unfortunately the alarm still does not work.
The replacement battery obviously has far less capacity.
My questions are
1. should it still work with the lower battery capacity? (since the alarm is also mains powered and all the mains trip switches look ok)
2. will the fire alarm still work?
3. Any other ideas as to a likely cause?
1. Yes
2. Is it connected to alarm
3. No .... What alarm panel is it ? Probably a galaxy ...
3. It could be a blown fuse... Cable damage by little "furry friends"...
Consider getting your local independent alarm company in to take the system over.
Sparkymarks.
Yes the fire alarm is connected to the system as I found to my cost. When my daughter first moved in I removed the cover of one to check the battery. Only there was no battery and it was tamper proof and the alarm went off!
Sorry, cannot tell you the alarm panel right now but will find out.
Eightytwo
Are there any fuses inside the main box? There is a problem around the house with squirrels, will try to get someone to look under the floor. Unfortunately we have no idea as to where all the wires run.
Re local independent alarm company - it could still cost quite a bit, it is likely that if we can't solve the problem ourselves she will install a new wireless system.
Hear hear.
...and, yes, there are fuses in the panel.
Although squirrels can't eat cables on a wireless system, you could have a whole host of other problems. Check out other posts on wired v. wireless systems. Whilst some people regard ADT as "the powers of evil and darkness", they usually installed good quality kit.
My local installers charge about half as much per hour as the local car main dealerships
