ADT alarm reset
16 Jun 2006
London
Hi all
My client recently moved into a new home. His ADT alarm is rather flaky.
When I exit I have to have the front door closed. After I press the whole house zone button and present the fob it will either make one beeping noise or say that it will set in 60 seconds and then make different beeps.
On entry I present the fob to the lcd, sometimes the alarm will trip as soon as I do that, other times it wont.
Today I turned up and the alarm made no noise so I assumed that the client had forgotten to put it on. I discovered later that it had gone off minutes after he left for work and had seemingly reset itself to a disarmed state.
Is it normal for alarms to reset to an off state, is it a legal requirement? Surely a burglar need only bang on a window to trip the circuit and then wait 20 minutes for it to turn itself off...
The engineer had already been booked to turn up tomorrow. I guess that I will be left a list of questions to give him from the client, I 'd just like to know if he feeds me BS about reset protocols.
Sounds like its not behaving correctly.
Sticky or faulty door contact is my first guess with the setting issues.
It may have rearmed but we dont know if it even set.
Reset protocols have nothing to do with this.
There is from the sound of it a faulty door contact, if there is even one fitted.
Thanks alarm
There is a visible door contact, surface mounted,
On the occasions that it trips it seems to be shortly after people leave the house.
I shall pass your suggestion on.
In short you are confirming that a single tripped zone should revert back to a full reset rather than disarm?
tnx
It will never go to disarmed after an activation. It will rearm according to how it is programed.
But disarm, never.
Again this points to a faulty contact and or programing.
