Hi, I am in the process of refitting our kitchen and am at the stage where I need to sort out the plumbing connections.
I have a copper waste pipe of 40.8mm OD coming out of the wall at just above floor level sloping upwards as shown in the photo....
....and would like some advice on the best options for connecting the plastic waste pipes to it.
I will need a 90deg bend sideways followed by another 90deg bend vertically to get the vertical pipe parallel with the wall. The options I can see are either 40mm pushfit fittings or compression fittings, both of which do seem to be a good fit. Once the sink cupboard is in place I will be a bit pushed for space, so a compression fitting will be more awkward due to it's bulkiness but is still doable. A pushfit fitting will probably be easier to work with in the confined space and I may even be able to avoid having to cut out the floor of the cupboard.
So really I just wanted some advice to help me make an informed decision.
Many thanks
Russell
Many thanks
Russell
