Hi there
I'd appreciate some advice before I start ringing around different plumbers for quotes.
I have a 10 year old Valliant 242 combi installed in our home... I'm also guilty of never having it serviced!!
Still for the past 10 years it has given us good service and been very reliable.
However it has now developed a small leak from what seems to be an expansion tank for the cold water/domestic hot water system. (this is black chamber on the left of the boiler). I can't see exactly where the leak is but it could be from the upper feed pipe that goes into the top corner of the tank... or from what i assume is a gasket that goes around the top of the tank itself. The top part of the tank is heavily scaled and the leak must have been there for some time I think.
Is this a fairly common fault?... would it be fairly easy to fix? any idea of part prices... and the likely time to fit should I get a plumber into do it.
Also the water temperature dial will not turn... not a major problem but it would be nice to be able to change this again.
Then I am thinking.... 10 year old boiler...no servicing... what else might be wrong....or go wrong soon...... should I possibly replace it completely.
At the tiome the boiler cost about £500... is that still around the going rate for a combi boiler. It was fitted with the Central Heating installation, but the boiler itself didn't take very long to commission really by the fitter. Assuming a new boiler would fit directly into place with the same piping connections do you think a straight swap would be fairly simple (and cost too much as well)
Thanks for your help.
