Hello, I wanted to get some advice on my recent planning application which got rejected. My architect is not much helpful and directing me down the route which she says could cost thousands.
So, here is my application: https://planning.welhat.gov.uk/Planning/Display/6/2022/0893/HOUSE
In the delegated report, the planning officer mentioned few things which I don't understand...
Firstly, he states:
From my understanding, he is talking about the length of the ridge of the extension. This, he says is 4.5M and I assume the 4.3 is depth of original house?
The house is little less than 6m by 7m. I don't understand how they got that figure of 4.3M.
Secondly, he states:
The rear projection clearly shows a small bit outside the original house but somehow this is not visible in front projection... I think this is architect's mistake?
Is there any way to circumvent the issues or am I doomed because of the corner property nature?
Also, I think most of the application is permitted development and the council has approved them under PD few years ago:
https://planning.welhat.gov.uk/Planning/Display/6/2018/1136/LAWP
Also, I found few other applications which are visible from the road as mine and their applications were approved for much larger extensions:
https://planning.welhat.gov.uk/Planning/Display/6/2022/0249/HOUSE
https://planning.welhat.gov.uk/Planning/Display/6/2022/0055/HOUSE
https://planning.welhat.gov.uk/Planning/Display/6/2021/3183/HOUSE
https://planning.welhat.gov.uk/Planning/Display/6/2022/0407/HOUSE
Firstly, he states:
Furthermore, the ridge of proposed gable roof of the extension would project approximately 4.5m at a point of the gable roof of the current dwelling which measures approximately 4.3m in depth. This disparity in size further emphasises the proposed developments bulk and massing.
The eaves to the left side of the proposed gable roof when viewing the dwelling from the rear would also extend beyond the existing eaves of the dwelling. The existing eaves project outwards from the front and rear elevations of the dwelling in a form that this is replicated at each end of terrace dwelling in the four blocks of dwellings located to the north side of Stonecross Road. The proposal would therefore interrupt this uniformity in the eaves and would consequently detrimentally detract from the character of both the application dwelling and wider area.
