advice on best boiler please
are you going to have a hot water cylinder, or a combi?
how many litres per minutes does your kitchen cold tap deliver?
Also I have checked my flow rates (mains, dhw) and it points towards a 28kw.
You say the cold water flow rate at the kitchen tap is 14.5 l/min. If you have a garden tap straight off the mains, check the kitchen flow with the garden tap full on.
I am having a quote on Tuesday for loft and cavity wall insulation so that should solve that problem.
Did you know that you might be able to get it for a very low cost or even free? Check out Energy Savings Trust Grant Search
Loft and Cavity insulation will reduce the heating requirement, it won't eliminate it. Use the Boiler Size Calculator to find out your heating requirement and see what difference the insulation will make.
When selecting the boiler make sure that the lower output limit for heating is well below the calculated heating requirement.
That is very good news but the £160 extra was what was involved with the 200 which I fitted about six months ago.
If the new Vitotronic 200 model is so much less then I am surprised the people at the show did not think it was worthwhile telling me. Not even the short German fellow!
Tony
don't be telling god he is wrong
Tony, you are wrong. We have fitted loads of 100 with W/C and the sensor plugs directly into the pcb, and cost approx £30 + Vat.
So be a big boy and hold up your hands, and say to Mysteryman ' I am wrong this time'.
Its easy!
