Hello,
Wondering if anyone can offer some assistance on an issue that we are having installing a new pitched roof.
Current progress is as follows:
Breathable membrane fitted
Tile lath fitted
800 Redland Regent tiles waiting to go
The roof is an L shape with a 16 degree pitch on the rear half and a 13.5 degree pitch on the side half. The issue is that with such a low pitch we are concerned about the guttering. The father in law/builder has noticed that the final tile at the gutter needs raising in order to improve the aesthetics of the finished roof and has suggested putting a second lath on top of the bottom roof lath in order to raise the tile up.
I see no problem with this however the next suggestion has me concerned, he wants to cut the membrane just behind the final lath and place 12" DPC underneath it to provide an additional water barrier (The membrane we have used is UV resistant for only 3 months so will begin to degrade after this), he has then suggested putting the DPC and the membrane over the top of the last lath in order to create a drip tray that the fascia can be slid underneath.
Problem is, with this shallow of a pitch the additional lath almost makes the final section horizontal on the 16 degree roof so the 13.5 degree roof will effectively have a trough so to speak.
I understand that there should be no water ingress through the tiles in a normal scenario and this should not be an issue of concern however cutting the membrane and reducing the pitch seems a bit strange to me.
I have attached an illustration of the current and proposed scenario so that it hopefully makes more sense.
how to make screen shot
http://postimg.org/image/ba9tqz32v/ Note: the angle shown is a bit steeper than it actually is.
Just a thought, is there supposed to be a batten at the bottom of the roof or can the tiles rest on the fascia board?
Thanks, Matt [/img]
Tile lath fitted
Thanks, Matt [/img]
