Hi chaps,
I have a flat I want to replace the floor in.
The existing floor is 60mm wide, 18mm thick american white oak tongue and grove solid timber, which has seen better days.
I have a few things to consider before I go out and buy the laminate.
Firstly, what's the easiest way to stop the dreadful squeaking? This is mainly in the footfall areas i.e. the hallway.
Secondly, do I need to ply out the whole area before fitting the new laminate?
Thirdly, do I need underlay?
The flat is on a ground floor, so no sound considerations.
In addition to this there is another option.
The existing floor could be de-squeaked, re-sanded and stained to something a little lighter in colour, but this will be labour intensive, and as I'm going to do the whole place myself I need to be confident that I'm going about it the right way.
The floor sits on timber joists sitting directly on the concrete.
The other consideration if I go the sand and re-stain route is the floor has been damaged and will need repair in places. I will need to source about 2-3m3 of american white oak from a timber merchants which could prove difficult.
This option would save removing skirting, cutting back architrave and all the rest, but will the finish be nice enough to justify all the work?
The flat consists of a lounge, 2 bedrooms, and a hallway, the kitchen and bathrooms are tiled.
