    Dismiss Notice
laminate over woodblock floor
Discussion in 'Floors, Stairs and Lofts' started by geome, 8 Mar 2013.
  1. geome
    geome
    7 Jan 2005
    79
    Thanks Received:
    Country:
    My house has ground floors of woodblock (parquet) which are in need of renovation
    I would prefer to fit a laminate or solid wood over rarther than renovate the existing floor
    Is this a good idea and do I need underlay
    What would you recommend Laminate,Real wood,or engineered wood
  2. WoodYouLike
    WoodYouLike
    14 Nov 2004
    7,710
    Thanks Received:
    215
    Kent
    Country:
    What ever you select, make sure the underlayment you use DOES NOT contain a DPM - which will cause condensation and effect the parquet floor (could lift up in the end)
  3. Sponsored Links
  4. crazydaze
    crazydaze
    30 Oct 2009
    945
    Thanks Received:
    141
    Surrey
    Country:
    Forget the solid wood option if you plan to fit over the top, laminate or engineered will probably be ok, although there is a 'risk' when laying over the parquet.
    As has been said, never use a DPM product and fibreboards would be better than the thinfoam underlay.
  5. geome
    geome
    7 Jan 2005
    79
    Thanks Received:
    Country:
    Thank you for your replies
    I am thinking of using a heavy duty laminate the type that can be used in kitchens and bathrooms (commercial) grade.
    Would this be suitable over the parquet with a fibreboard underlay
  6. Sponsored Links
  7. crazydaze
    crazydaze
    30 Oct 2009
    945
    Thanks Received:
    141
    Surrey
    Country:
    None of this really makes clear sense, bathroom stuff means the sub board is dimensionally more stable than standard HDF cores but it has no relation at all to how hard wearing the laminate is, nor does it reflect how suitable it is over parquet.
    Look at really good quality brands like Pergo, they are engineers superbly and have the highest quality picture and wear layers in the laminate world.
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
