Hi Guys
I need to build a desk into an alcove for a computer, monitor and stuff. I'm planning on using batons and a slab of MDF fitted into the alcove. What thickness MDF, size of batons and screws would you recommend?
The alcove is 1300mm in length, the width of one wall is 360mm and the other about 700mm, ideally the width needs to be about 600mm. Will this be a problem on the short wall? Should I support that side with a leg or can I curve the desk to go from 360mm to 600mm and not need any extra support?
I need to put this up in hurry and don't have time to make and rectify the mistakes I normally make when trying to build stuff
By the way it needs to be able to take a CRT monitor short term which is pretty heavy but hope to replace soon with an LCD.
Thanks in advance
Thanks in advance
