i have an awkwardly sized bathroom, i am tiling the whole floor and all walls.
due to the size of the corner where i want to put my shower and the distance from the corner to the window edge, the enclosures that are available are very small and poxy.
i would like to make a shower tray/wet tray and buy a walk in shower screen which i could position where i like and not be confined to 670-700mm.
my initial thoughts are, if i layered say 2 pieces of 15mm-20mm marine play on top of each other then raised these off the floor with a wooden frame made from 2x3's( to stop flex in the ply, that would raise it up enough to attach a waste pipe/outlet. i would then coat the marine ply in waterproof adhesive and use water proof grout. I just dont know if this would be water proof enough?
it will be designed so that the water will run toward the plug etc. i havent got £800 ish to spend on the ready made wet room floors etc, but what im after is something similar to these:
http://www.myvouchercodes.co.uk/cheapest/Aquadry-Wetzone-50mm-raised-1850x900mm/23031992/434
http://www.diy.com/diy/jsp/bq/nav.j...refview=search&ts=1251109390633&isSearch=true
can someone tell me if my marine ply and frame tiled shower upstand would do the job and be waterproof enough? the tray would be roughly 1000mm by 1200mm and a curved screen would be placed on the wall arounf the 670mm marker, the curve would allowa little extra room.
this is a crappy paint drawing of my bathroom.
