Advice on replacing isolation valve.
27 Jun 2011
Hi guys,
The isolation valve up in the loft is weaping (from the flat head screw)
It's a compression fitting.
My question is, can I just replace it with the appropriate sized handle valve? (It's a 22mm)
More specifically, can I re-use the existing nuts on the pipework and just screw them into the new valve or must I remove the old olives and use the ones that come with the new valve?
(Have uploaded a pic if it helps?)
Thanks for any help.
View media item 56575
The basic answer is 'yes'.
It looks to me like someone has already done that - shiny body and dull nuts.
It is possible that the pipe recess within the new fitting might be deeper than your existing fitting, which isn't ideal, but isn't a dealbreaker on what I assume is an open-vented / gravity system. If you can move the olive to suit the new valve body, do. Some move quite easily - others not.
Get some ptfe tape while you're at it and wind 2-3 turns around the olives before you put it back together - and don't overtighten it! Don't use a spanner on the body of the new valve either - unless it has flats for that purpose.
Oh, and make sure you are certain the pipe is largely empty before you start!
depends if the old olive was put on so tight its grinched the pipe big time, in which case a bit of ptfe does certainly help. but always use paste with olives.
Err the basic answer is yes, so long as it is the same make.
99.99999999999999% of manufacturers 22mm compression threads are NOT compatible.
:?: :?: Olives should not move at at all, surely.
Brass nuts, chrome body.
I must've been reallllllllyyyyyy lucky then. And the bloke who swapped the shiny chrome body onto the dull brass nuts got lucky too!
I should go and get myself a lottery ticket I'm so lucky!
:D
Good point, it does look as though someone has already done what I'm suggesting.
No, it's the cold water feed to two electric showers. (Yes, I know I shouldn't have even touched this valve, and simply used the cock under the sink.)
I wasn't expecting the olive to move at all, that's why I was asking if can leave it in place and simply fit the new valve with the old nut/olive that's already on the pipe?
If the olive moves, then I'd simply remove it along with the old nut and use the new ones supplied with new valve.
If it doesn't have flats for a spanner, how should I hold it steady?
